50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Void in a Wall
Tue, Feb 8, 2005 at 10:57:45 PM | Void in a Wall
wparish
Hey Guys.. The firm that I work for just started Revit and I am the first person to use it on a project. So I am new to the game..As simple as it may seem, I need to know how to put a void(12'-4"high x 21'-8"long) in a CMU/Brick wall that is 20'-0" high. So that I can put an CMU/EFIS wall In.. I am up for any and all suggest/comments. Will
Wed, Feb 9, 2005 at 1:00:29 AM | RE: Void in a Wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Welcome to the wonderful world of revit and good luck. you can use the opening tool in the modelling tab to draw an opening, or you can simply select the wall in elevation and choose-->edit profile from the top of the screen then sketch the opening you require. HTH.
Wed, Feb 9, 2005 at 11:21:36 AM | RE: Void in a Wall
wparish
Thanks for the info..I ended up using the edit profile command from the elevations. Its amazing what one might find in the "Help" option. By the way..I noticed that you were 2nd in rank on the website..Hopefully one day I will be at a point to where I even make it to the top 10... Thanks again for your insight... Will
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
Wall Hosted Family cutting void into Wall
Mon, Aug 23, 2010 at 3:58:59 PM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:06 PM
Void forms
Tue, Sep 6, 2011 at 5:53:33 PM
12
Cutting wall end with in-place void - Revit 2018
Thu, Jul 6, 2017 at 5:08:30 PM
Page generation time: 0.7414
