79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> View DWG above objects?
![lorne17 Avatar](user_avatar/39394.jpg)
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Is it possible to view the imported .dwg link above the walls? Or ghost it so I can see it? Because once my walls are drawn they cover up all the windows and I don't know where they go? Just curious if there is a simple way around this. Thanks, Lorne17
Denver, CO
Revit Architecture |
Also, I'm using Revit 9.1
Denver, CO
29 Posts No Rating |
Hi, To see your DWG through your walls, change your Model Graphics style to "Wire Frame".
Well since this post is so old, I have found out how to do this. All you do is select your dwg and under the options bar, change it from background to foreground. However if you brought it in to be in ALL views, then I don't believe this option is available. If that's the case, use wireframe view. Lorne
Denver, CO
Exporting views with DWG bocks to dwg. |
Sun, May 21, 2006 at 8:36:59 PM
DWG and revit preformance |
Mon, May 15, 2017 at 2:24:05 AM
Importing DWG or DXF file objects |
Wed, Jul 12, 2006 at 10:45:32 AM
Help: Print transparent objects from floor plan view to pdf in revit 2013 |
Tue, May 8, 2012 at 2:49:41 PM
3D DWG as a Mass - Visibility Problem |
Fri, Sep 5, 2014 at 1:30:53 AM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
