57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> General family question
Tue, Sep 25, 2007 at 11:47:22 AM | General family question
supercadder
supercadder Avatar
I am using Revit MEP 2008. Can a family be dynamic like the dynamic blocks in autocad? Example I have a dome camera family that I need to show which direction the camera is to be pointing for the installer to aim it. I want to have an arrow that rotates around the center point of the dome. Can I do that in one family and change the arrow rotation per instance in the drawing? I have included my family to help describe my problem. Any help would be appriciated.
 Thanks,
Doug
Thu, Jan 10, 2008 at 8:18:58 AM | General family question
norby
Hi,
Please have a look at attached fille...
Regs.
norby
Thu, Jan 10, 2008 at 12:28:05 PM | General family question
NKramer
4 Stars: 9 Votes
As you can see from norby's post you can do pretty much the same thing in Revit families as you can with dynamic blocks. I had just started to get into dynamic blocks when we switched over to Revit. I find that Revit can do a lot more than AutoCAD but it can be a lot more complicated.
You really need to be able to wrap your head around formulas to be able to get some of the visibility state type options to work in Revit.
Personally I dont use RevitMEP but I understand that it can really be a bear to get all of your families correct in plan, 3d, wiring, etc. On the bringht side if you have questions/ problems people are useually pretty good about helping you figure them out.
Nick
Is this a Tips and Tricks forum or a side door to the General Discussion forum ?
Tue, Aug 22, 2006 at 11:05:46 AM
General notes & vent calcs
Tue, Oct 11, 2005 at 6:15:05 PM
General Contractors Using Revit
Mon, Sep 29, 2008 at 2:09:35 PM
12
Importing General Notes
Wed, Feb 9, 2011 at 8:08:30 PM
GENERAL REVIT QUESTION - help please
Fri, May 30, 2008 at 12:21:30 PM
Page generation time: 15.1787
