34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Cable tray in Revit MEP 2008
Tue, Sep 25, 2007 at 10:05:30 AM | Cable tray in Revit MEP 2008
JMAJORS
I am working on trying to place a cable tray in Revit MEP and have had no luck so far.  Any ideas for a work around?  I have tried the Massing tools but I am still working on getting those to display properly.  Thanks for any ideas.
James
Tue, Sep 25, 2007 at 11:41:44 AM | Cable tray in Revit MEP 2008
supercadder
supercadder Avatar
I posted a cable tray family that I found. It is in the download section under low voltage electrical distribution. It seem to work pretty good though I have not put it to use just yet. Let me know how it works for you and if there are any other querks you find to make it easier to use.
Tue, Sep 25, 2007 at 5:14:02 PM | Cable tray in Revit MEP 2008
JMAJORS
Thanks for the help.  We were able to use those files to create a solid bottom cable tray.  Thanks again.
Wed, Sep 26, 2007 at 1:30:55 PM | Cable tray in Revit MEP 2008
JMAJORS
Here is the cable tray with a solid bottom instead of rungs that we have created.
Sun, Mar 16, 2008 at 3:29:34 AM | Cable tray in Revit MEP 2008
aaamahmoud
THIS FAMILY IS VERY GOOD
PUT I CANT MAKE CHAMFER CONNECTION BETEWEEN THE CABLE TRAYS
YOUR REPLY IS URGENTLY NEEDED
Fri, Jan 23, 2009 at 2:52:40 PM | Cable tray in Revit MEP 2008
duhgus
supercadder the cable tray families work great...exactly what I was trying to accomplish. (Adjust the length and have the rungs automatically added with the ability to adjust the width, height and rung spacing) Do you wave a cross and 90 elbow as well?
Thanks!
Wed, Jul 29, 2009 at 3:39:53 AM | Cable tray in Revit MEP 2008
prashantgholap
I know that this in revit forum, but still I want to share cable tray blocks which are created in AutoCAD. We searched a lot for getting real life cable trays which we can use in our modeling project. We were able to find some 2d dynamic blocks Cable tray, Revit families with some limited functionality. Also we tried to create cable tray in AutoCAD MEP, but we gave up after some time. Lastly we tried to do this by using AutoCAD 3d objects & then giving it dynamic properties. To our surprise we were able to do this & found that by doing some twicks we can add dynamic blocks properties to 3d objects too. We are very pleased to share this with Augi community. Do place your feedback about this
Cable Tray- Revit MEP 2013
Fri, Oct 5, 2012 at 8:29:45 AM
Cable Tray Clearance
Mon, Mar 24, 2014 at 10:44:48 AM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Revit 2015 - Ladder Cable Tray
Mon, Feb 29, 2016 at 5:05:14 PM
Page generation time: 1.9805
