53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> new developments in the estimating front?
Tue, Feb 8, 2005 at 10:44:55 AM | new developments in the estimating front?
artifact
Has anyone found anything that works (for reasonable cost) for using a revit model for estimating construction costs? I have looked at the Timberline software but found it to expensive. I've also discussed with Ken Stowe his system of schedules exported into an Exel spreadsheet. It requires significant time to set up the excel sheets. This is probably the route we will go unless something better comes along. The old pre Revit 6.1 export to Means Costbook option sounded great! Will it return? Thanks!
Revit and Timberline Estimating Extended
Thu, Mar 8, 2007 at 3:07:29 PM
Revit & Cost Estimating
Mon, Jul 12, 2010 at 9:42:34 AM
RS Means Estimating?
Wed, May 5, 2004 at 9:41:57 AM
Exporting Revit to Master Builder Estimating Software
Wed, May 21, 2008 at 8:19:43 AM
COST ESTIMATING WITH REVIT
Mon, Jul 12, 2010 at 9:39:43 AM
Page generation time: 1.1376
