86 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> Dimension Leader
![DTCesarz Avatar](user_avatar/21006.jpg)
![5 Stars: 4 Votes](/images/stars_5.gif) |
Is there a way to change Revit 2008's default arc dimension leader. I would prefer to create one with straight lines and elbows. Thanks.
You can either click on your text after you've typed it, then choose one of the leaders in the option bar. Or you can click on the text > properties > uncheck "arc leaders". HTH JB
Yeah, I can get that to work with the text just fine, but not with dimension strings. If I drag the number so that a leader appears its always an arc leader. In order to be consistent w/ out text leaders (which have elbows), I would like to make the dimension string leaders the same. Thanks
Sorry, my bad. I mis-understood you. As far as I know I don't believe you can alter the arc when you drag the text. JB
Revit Dimension Straight Leader Line with Controllable Node at Elbow |
Thu, Jul 12, 2018 at 12:32:47 PM
Multiple Leader Text |
Sun, Nov 18, 2007 at 12:33:40 PM
Adding Snaps to Leader Lines |
Thu, May 29, 2014 at 7:34:34 AM
Leader Question |
Thu, Jun 16, 2016 at 12:24:28 PM
Positioning the leader on a tag. |
Thu, Aug 6, 2015 at 12:16:39 PM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
