71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> cant rotate fill patterns
Fri, Sep 21, 2007 at 2:14:36 PM | cant rotate fill patterns
LUCAS1979
1 Stars: 1 Votes
hey... I have imported couple hatch patterns from cad...when i did i only had option to change scale...now i need to play with their orientation but it seems that when i go to edit that imported pattern does not have option to rotate (like in simple patterns);  I tried switching it to orient it to object but hatch still wont rotate...?
Fri, Sep 21, 2007 at 2:30:29 PM | cant rotate fill patterns
Check out the difference between 2d and 3d hatches.
Mon, Nov 17, 2008 at 2:36:03 PM | cant rotate fill patterns
AmyCRErde
Hey Lucas, did you ever get a real answer to this?  If so, please share!  I can't figure it out wither.
Mon, Nov 17, 2008 at 3:38:22 PM | cant rotate fill patterns
The real answer .... Model hatches (3d) can be rotated - 2D (drafting) hatches can not.
Look it up in your H E L P !  Rotating a Model Pattern
Mon, Nov 17, 2008 at 3:47:26 PM | cant rotate fill patterns
AmyCRErde
So if Revit won't import my hatch pattern as a Model Hatch,(It actually refuses to do it) I'm just Out of luck on that pattern?
Mon, Nov 17, 2008 at 4:41:54 PM | cant rotate fill patterns
iF YOU HAVE A 2d HATCH PATTERN, ALL YOU HAVE TO DO IS EDIT IT AND ADD 1 LINE OF TEXT.
;%TYPE=MODEL
SECOND LINE OF TEXT IN THE FILE.
Sorry for the caps
Edited on: Mon, Nov 17, 2008 at 4:42:55 PM
Tue, Nov 18, 2008 at 8:20:37 AM | cant rotate fill patterns
AmyCRErde
Got it.  Awesome, thanks!
Wed, Nov 11, 2015 at 8:03:11 AM | cant rotate fill patterns
Jimmybebop
RE: adding the line %TYPE=MODEL. Where is this added? I opened a .pat file and added another line at the bottom, but this didn't work. What am I missing?
Wed, Nov 11, 2015 at 8:05:44 AM | cant rotate fill patterns
Jimmybebop
Never mind... left out the semicolon. Does work.
Rotate Model Fill Patterns [ 1 2 ]
Sat, Nov 28, 2009 at 5:21:55 PM
15
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:51 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:10 AM
A few questions
Tue, Jun 30, 2009 at 11:25:54 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:01 AM
Page generation time: 1.7741
