69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Sloping wall
Thu, Sep 20, 2007 at 11:36:31 PM | Sloping wall
pacho
hi, i am from Colombia, i need help to made a organic wall like a spiral, a sloping wall, please help
Fri, Sep 21, 2007 at 12:26:21 PM | Sloping wall
The most advice I can give is to check out how to create a mass then do wall by face.  Check out REVIT help on these things.
Fri, Sep 21, 2007 at 1:30:16 PM | Sloping wall
lpromana
4 Stars: 2 Votes
Hi Pacho
I'm from Colombia too, living in the USA now can you send a picture of anything similar to what you want to do maybe I can help Smile bienvenido a Revitcity
Fri, Sep 21, 2007 at 4:54:44 PM | Sloping wall
pacho
MIra este es parte del archi, necesito conectar la parte superior del muro con  esa piso mas pequeño, si me puedes dar tu correo o msn te lo agradeceria el mio es guano_guano@hotmail.com
Fri, Sep 21, 2007 at 5:00:09 PM | Sloping wall
pacho
imagen
Mon, Sep 24, 2007 at 9:10:38 AM | Sloping wall
lpromana
4 Stars: 2 Votes
Hi Pacho
this is what you can produce using the massing tool creating a blend and then using the curtain system tool in the massing tab to convert the faces from the mass into curtain walls I hope it helps Smile
sloping wall
Tue, Nov 2, 2010 at 4:16:23 PM
Sloping Wall Sweeps (Revit 2008)
Sat, Jan 26, 2008 at 9:13:08 PM
Sloping wall capping
Sat, Oct 17, 2009 at 4:58:30 PM
Help... Applying Rendering Texture to Sloping Wall
Mon, Dec 8, 2008 at 5:47:54 AM
Precast on curved sloping wall
Sat, Nov 22, 2008 at 1:35:25 PM
Page generation time: 1.6390
