54 Users Online (52 Members):
Forums >> Revit Structure >> Technical Support >> Revit Structure 2008 SP2: Join Geometry on differnet beam families
4 Posts No Rating |
Hello. Does anyone know why you aren't allowed to Join Geometry on steel sections (i.e. Wide Flange Beams) and in-place families, to cut only parts of theese, when this can be done without any trouble on for instance concrete beams? With Join Geometry active I simply cannot click on the steel profiles. All the beam families are sweeps, and I've tried cutting with in-place Generic Models, Masses and Structural Framing. Pictures tell more than a thousand words, they say. The one I've attached tells hardly more than 10, but perhaps it'll help clear some things out.
Altering Revit Structure Wood Beam Families |
Mon, May 14, 2012 at 2:10:01 PM
beam join command |
Sun, Dec 23, 2012 at 11:50:10 PM
beam and wall connection |
Mon, Nov 23, 2009 at 12:24:04 PM
wall & beam join |
Thu, Jul 2, 2015 at 8:49:21 PM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Members: | 2022246 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
