81 Users Online (79 Members):
Forums >> Community >> Newbies >> Revit Families
19 Posts No Rating |
I am very new to families in revit 2008. I need to define a window in a wall that is 1'-6" thick and the interior opening is different from exterior opening, all exmaples have a host wall of 6" and thus I am unable to progress ver far also what is the difference b/w opening and instance opening in the web library, thanks
The host wall in the family editor is editible to be any width you want it to be. I recommend duplicating it and making may different widths and then changing out the host wall type in the family editor to see how your family reacts to the change. To edit the wall simply select it and go to its properties just like a wall in a project. For the opening, you have to use the tools that are availble in the editor. You can use the 'opening' tool or you can have a void that cuts the wall. You can only have one style of opening though and in your case it sounds like the void would be the best option since you want an opening that is a different size exterior vs interior.HTH
Tom www.reviteer.com http://twitter.com/Reviteer |
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
Revit Families |
Fri, May 24, 2013 at 4:23:33 PM
12
Rendering Families in Revit 2010 |
Mon, Jul 19, 2010 at 5:39:45 AM
Locking Revit Families |
Thu, May 5, 2011 at 1:30:33 PM
Edit Default Families |
Sun, Jan 24, 2010 at 8:23:42 AM
Members: | 2057574 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
