79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Arrays Mulitple and parametric
135 Posts No Rating |
Hi all, building an baluster-panel family! I need to create a grid array pattern, each element [ geometrically a void] in the pattern is the same, but i would like to make the width ,height and spacing parametric. the elements are square but 45degrees rotated! problem 1: the array is really slowing down the performance problem 2: to parametrically dimension the spacing is nog possible somehow problem 3: updating the parameters is slow and not correct! how to? the baluster panel should in the end be an cnc-milled or perforated plate, the pattern is the data that should be cutted from the plate?
hi all, i do have big difficulties to create a baluster panel that nicely fits to corners! the problem seems to be that the alignment of the panel [width = fixed to 2000] does not wrap nicely with the sketch! is there a good tutorial for this item? E
2 Posts No Rating |
Hi, Did you have the baluster panel issue resolved? I am working on similar problem creating a perforated panel, but cannot adjust the holes to show correctly as a parameter.
Parametric Arrays - Detail Item Help! |
Fri, Jan 29, 2021 at 9:03:59 AM
Parametric Arrays |
Fri, Feb 5, 2010 at 3:19:22 AM
Parametric Arrays? |
Wed, Apr 1, 2009 at 3:38:48 PM
Revit 2009: Familly with parametric arrays - Voids wont cut |
Tue, Aug 19, 2008 at 3:46:02 PM
Multiple Paramteric Arrays on a beam |
Thu, May 17, 2012 at 3:01:18 AM
Members: | 2081105 | Objects: | 23122 | Forum Posts: | 152272 | Job Listings: | 3 |
