68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Random objects
Wed, Sep 12, 2007 at 1:47:44 PM | Random objects
Audra
 I'm new to Revit, just started last Friday.  I'm using v. 8.1 and picking up comments on a project started by someone else.  I just noticed some random lines in one of the views that turned out to be a huge set of double glass doors.  I can't delete them, edit them, move them, nothing.  Please help.
Wed, Sep 12, 2007 at 9:08:36 PM | Random objects
sdbrown
5 Stars: 3 Votes
If the elevation or section marker location passes thru the swing of the door in plan you wil see the lines. If you can move the section or elevation cut line away from the door swing.  If not you should be able to find the door subcategory they are on and turn it off, go to VV and hit thte plus next to the doors and turn off stuff until you get it.
Thu, Sep 13, 2007 at 7:21:36 AM | Random objects
Audra
Thanks!  I was finally able to remove the offending door by deleting it from the door schedule although I still have no idea how it got there in the first place.
Random flying objects in perspective views
Mon, Jul 18, 2011 at 6:14:26 PM
Spot Elevations - Random snapping.
Tue, Feb 21, 2017 at 6:19:05 AM
Random stone walls
Thu, Jun 26, 2008 at 5:04:39 PM
array of nested objects
Tue, Oct 14, 2014 at 2:27:27 PM
Revit 2010 printing random lines
Mon, Jan 4, 2010 at 10:51:09 AM
Page generation time: 2.1581
