43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Why are Spot Elevations so unreliable?
Mon, Sep 10, 2007 at 6:38:43 PM | Why are Spot Elevations so unreliable?
lfborrero
I have a street level plan, composed of various slabs at different heights. During the last month I have been working with the spot elevations command quite unreliably. I simply cant figure them out. Sometimes I can  place them (they appear) perfectly on the center of a slab, others they will only appear on the edges of the slab (I understand this happens on a tilted slab, but on a flat one???), and in some other cases they will not appear at all. I tried applying them in different views, levels, but the only clear thing is that there is no consistency on how they work. I even tried copying them and pasting them and it almost lets u do it but then it says that you have to Edit the Paste, and then it falls from there.
Can someone clue me in on how spots elevations are conceived in REVIT, to see if I can work them properly finally?
 Thank you
 Luis
Mon, Sep 10, 2007 at 8:50:45 PM | Why are Spot Elevations so unreliable?
sdbrown
5 Stars: 3 Votes
I've seen the same behavior. I wish I could help.  It seems like if I close a view and reopen it, I can place them again.  It doesn't seem logical.  I'll let you know if I figure it out.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:12 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:29 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:36 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:55 PM
13
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:15 PM
Page generation time: 0.3846
