73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Wall Joining
Mon, Sep 10, 2007 at 4:11:30 PM | Wall Joining
dlrenier
I have 2 stone walls, one on top of the other, except the upper wall has a stud layer and a finish on the other other side and and the lower wall is only the stone layer. When i look in the elevations and 3D, there is a line seperating the two and the join geometry tool will only fix the line in section view. Using the linework tool and making all of the invisible lines fixes this, but is there an easier way?
Mon, Sep 10, 2007 at 5:01:26 PM | Wall Joining
Sounds like they may be very slightly off in vertical alignment.  Try moving one wall in section then re-aligning it face to face.
Parapet wall sweeps not joining
Fri, Oct 25, 2013 at 3:00:32 PM
Roof Joining Issue
Mon, Jan 21, 2013 at 7:54:18 PM
12
Wall Joining Issue Revit 2015
Wed, Nov 4, 2015 at 7:56:51 AM
11
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Keeping walls from snapping
Fri, Jul 21, 2006 at 12:06:03 PM
Page generation time: 1.9680
