61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Viewport titles moving
On one of our sheets all of the viewport titles are shown where we want them, but when we print (or print preview) they all appear at what seems to be the origin in the lower left corner (they are all stacking on top of each other). This doesn't happen in any of our other sheets in the same project. Any ideas what would cause this?
We've figured out that it has to do with vector processing in the print setup. It was fixed when we changed to raster processing.
69 Posts No Rating |
any clues as to why? it just happened on only one of our sheets where we'll be required to click rastor process vs. vector.
9 Posts No Rating |
Revit 2008?
the problems we had were in revit 2008. we haven't had any issues since we switched to raster processing. we are now in revit 2009, and haven't had any problems with vector processing as of yet.
9 Posts No Rating |
I have to fix this problem it happening more often. Raster printing makes the pdfs to large to send out. ANY IDEAS?
We use Cute PDF to make our PDF's and have never had a problem. Which PDF writing program are you using?
we also use Cute PDF writer and haven't had any problems. our problems were with our physical plotter. maybe your plotter program isn't communicating properly with revit; maybe you should check to see if there are any updates you need.
Viewport Titles |
Thu, Jun 30, 2011 at 8:19:48 AM
Multiple Viewport Titles in same sheet |
Wed, Jul 30, 2008 at 7:16:18 PM
Purge unused Viewport Titles |
Thu, Aug 30, 2018 at 10:41:49 AM
11
Viewport titles - how to modify them? |
Sat, Feb 2, 2008 at 9:40:37 PM
Cleaning Up Viewport Titles |
Mon, Oct 1, 2012 at 3:19:59 PM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
