Forums >> Revit Structure >> Technical Support >> ARRAY INSIDE A FAMILY
89 Posts No Rating |
Hi there, i have got a cabinet family which has a parametric length and variable number of doors. i can change the number of door and the door size and location is changed accordinly. when i change the length the doors the doors adjust accordingly. the door is an inserted family which adjusts to the family parameters. i have copied the door panel (and ungrouped the array) and made a new array and gave it the same parameter name it responds as expected when the number of doors is changed. if i change the length however, the door size is changed as it should but the spacing is still according to the previous door width. (the doors either overlap or have gaps between then) the array has been made with the "move to second" and with the contrained box unchecked how do i make this array so that it adapts itself to a new length? somehow someone did manage to do it before i got this family. would someone please help? robert.
Hi, Its a little difficult to answer correctly without seeing your family file. However, it sounds like you need to add a parameter that controls the spacing of the array objects, Please post your family file and I'll take a look,
thanks Anthony, i am just trying to attach a file now the row of doors in front of the cabinet was created when the cabinet was 3400 long. when the length was set to 2400 long the door width changed to suit the new length but the doors remained in the same location and we now got gaps in between. if you change the length back to 3400 you see the second row of doors overlap. thanks for your help this should be breeze for a kiwi cheers robert.
Hi Robert, Modified family file attched, does this help? Regards Anthony
Thanks mate, that's a little ripper. would you please tell me what you did because this is just a little test family. did you create a new family for the door? i applied a the panel width parameter to to the door panel before making an array and hah the same prob. then i applied the same parameter to the door after the aray was made and that seams to keep it stabel is this the correct way of doing it? or did you do it differently? i have asked many people about how to do these arrays, but you are the only who gave me a solution thanks so much, robert.
You just needed to add a parameter that controlled the positioning of the panel doors; In this case I used the panel width that was already defined. Thus when Revit draws arrays the cabinet doors, Revit will know how far apart to position each instance. I hope this helps
thanks that's what i was after. just curious how it actually "locks onto it" does that parameter actually replace the picked distance? it would have made more sence if , instead of picking a distance, a parameter could be entered cheers, bob.
0. Hi Anthony, sorry to bother you again. what you did works perfectly. i still have a problem. when i change the number of panels , my array does not respond to it it changes the panel width but the number of panels remain the same. would you be good enough to give me a step by step of the array and all the settings? to start of, what is better aN imported family or just an extrution for the door panel? do you make a group of it? if we decide on a family say and then start the array, which items do we tick? do set the number of the array in the option bar or on the screen? and how do we make the array respond to a subsequent change of numbers in the family? thanks so much, robert.
maybe this can help give you some insight to arrays and nested families http://www.revitcity.com/tutorials/arrays_and_nested/ HTH
thanks Coreed, that's a good tutorial best regards, bob
Editable nested family inside parametric array host family |
Wed, May 19, 2021 at 8:05:23 AM
Family w/ Array Formula |
Fri, Mar 23, 2007 at 9:29:38 AM
2-dimensional Array of Arrays |
Wed, Aug 3, 2011 at 7:47:13 AM
Radial Array in a Family |
Mon, Apr 11, 2005 at 8:56:13 PM
Array on a Parametric Face |
Tue, Mar 7, 2017 at 5:09:11 PM
Members: | 2115395 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
