80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Groups, creating; Text and model element do not move together
Sat, Sep 8, 2007 at 5:55:50 AM | Groups, creating; Text and model element do not move together
boydj
I am creating a place holder for a piece of factory equipment.
I created an "Electrical Equipment" component - just a basic 3D box.  I then finished that component and then added text right on top of the box.  I then grouped the text and the newly created component (box) together.
Now, when I go to move this new group.  The text and the box float independent of eachother.  Almost like two boxers in a ring floating around eachother.
Why do they not stay together as one group when I move the group?
Sat, Sep 8, 2007 at 6:13:39 AM | Groups, creating; Text and model element do not move together
boydj
I think it has something to do with the fact that I included text (not model text created within the component) when forming the group.
Thanks,
Boyd j.
Sat, Sep 8, 2007 at 8:18:31 AM | Groups, creating; Text and model element do not move together
Why didn't you do this as a family? The wording could have been 3d text in the family or you could have added a parameter that you read and tagged in the model.
Sat, Sep 8, 2007 at 10:04:15 PM | Groups, creating; Text and model element do not move together
boydj
have not really gotten that much into creating families...i know that might have been a better way of doing it.  I did not want to use 3d text because i am always thinking about the size of the file and the load it might have on my computer - especially when the model becomes rather full.  I will try it in a family and make the leap into family creation.
thanks for your comment
Tue, Jan 15, 2008 at 11:33:39 AM | Groups, creating; Text and model element do not move together
Luiherr
I have the same problem of model texts in groups that  when moving they float separated from the group. Make families is not a solution for me because I'm creating 60 simple diferent boxes with a name for mechanical equipment in each one. I need to arrange them in the most efficient way but every time I move them the text is somewhere else. It is there some property that tie permanently the text to the model?
Tue, Jan 15, 2008 at 3:09:17 PM | Groups, creating; Text and model element do not move together
Add a parameter to your family and then use a boxed tag to tag it.  When you select "tag all not tagged" and use no leader, the tag will center over the family.  If the item gets moved far away, the tag will show a question mark.  When that happens, click on the tag - click on leader then click it back off and the tag will move to the family.
Details groups locked to model elements, possible?
Mon, Aug 29, 2011 at 7:23:06 PM
Text (in plan views) on a user-created family element
Tue, Oct 31, 2006 at 11:19:59 AM
Self-Illuminated Model Text
Mon, Jul 28, 2008 at 5:56:02 AM
Creating office templates & transfering model information
Mon, Jan 4, 2010 at 1:02:38 PM
Model Groups
Fri, Oct 13, 2006 at 7:31:57 PM
Page generation time: 1.0811
