75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Hidden lines in elevations
Fri, Sep 7, 2007 at 4:06:54 PM | Hidden lines in elevations
TJKENNEDY
3 Stars: 2 Votes
Is there any way to get hidden lines to show up in an elevation? As far as I can tell I have the view properties set correctly, but no hidden lines show up. If I use a section instead of an elevation everything looks correct, but I would rather not use that work-around if I do not have to.
Fri, Sep 7, 2007 at 4:43:57 PM | Hidden lines in elevations
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
Hi, here's a little workaorund: go to the elevation, turn to wireframe, select the show hidden lines tool, select 1st the object that hides something, and 2nd select all the hided element you're interested in to show up. Definitvly turn on hidden line (digit HD) and you will see the hidden lines of the element you selected. To control the visibility you have to edit the hidden lines of the category in the object style of the view.
Hope this help you a little bit.
-paolo
Mon, Sep 10, 2007 at 9:43:07 AM | Hidden lines in elevations
TJKENNEDY
3 Stars: 2 Votes
Thank you. That method is a tad time consuming, but it is working.
Hidden Lines disappeared from all my Elevations
Fri, Mar 1, 2013 at 12:37:05 PM
Elevation/Creating Hidden lines
Fri, Mar 12, 2010 at 12:43:18 PM
Show hidden lines
Wed, Apr 16, 2008 at 5:52:56 PM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:51 AM
MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
Fri, Aug 11, 2006 at 1:18:16 PM
Page generation time: 2.4927
