78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Draw Order: components that are gray blocking my black wall lines??? help??
Fri, Sep 7, 2007 at 3:09:56 PM | Draw Order: components that are gray blocking my black wall lines??? help??
jmqrsq
5 Stars: 3 Votes
Hello again. I cannot figure this one out. Here is a screenshot of my problem. Is there a hierarchy of objects list somewhere or a draw order  command out there that I can use to control things to be in the "foreground" and "background"? I am not specifically talking about images and autocad files as those are no problem. Native Revit items are causing me the most trouble. Notice the gray thin line on top of the black thick line in the first example pic. The second pic shows a component "hiding" a portion of the walls thick black line. I really do not want to have to go into all of our families to do a fix if I do not have to.
Thanks in advance,
JQ
Fri, Sep 7, 2007 at 4:09:13 PM | Draw Order: components that are gray blocking my black wall lines??? help??
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
Hi, the solution I've came up with is to modify the line weight of the wall line that appears under the component using the line weight tool, and selecting the proper line type in type selector. The images attached explain better then 1000 words.
Hope this help you a little bit.
-paolo
Print color lines in Black
Fri, Aug 8, 2008 at 11:15:35 AM
Revit 2008 - changing pattern overscaling color from gray lines to black
Tue, Nov 20, 2007 at 6:25:41 AM
Draw Order for Wall Sections?
Tue, May 18, 2010 at 11:32:31 AM
change draw order - make lines and images show on top of components
Thu, Aug 16, 2007 at 10:42:11 AM
Existing Walls Printing Black (SHOULD BE GRAY)
Tue, Mar 27, 2007 at 12:42:29 PM
Page generation time: 2.3612
