58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Title Position
![quiller Avatar](user_avatar/665.jpg)
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
If I rotate a view on a sheet, is it possible to also rotate and move the title so it's at the bottom of the view when I'm finished?
Cheers......Alan
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Yes.
Instead of using the view properties, rotation on sheet tool. Select the crop region of the view and rotate 90º, this will effectively rotate the view but leave the view title at the bottom.
HTH.
Hi,
I don't follow. If I rotate the crop region (at the floor plan level) the only thing that rotates is the crop, not the view. I want to place the views on a sheet so they read better, if you take a look at the attacted doc, it may help.
Cheers......Alan
Bugger i'm sure that used to work.
The only other way i can think would be to create a new view title where the text is rotated. You could then use this for the rotated views.
HTH.
viewport title with line question |
Tue, Jul 8, 2008 at 11:38:17 PM
Viewport title locked. How to unlock? |
Tue, Sep 30, 2008 at 3:20:48 PM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
Aligning text position in different labels. |
Fri, Sep 25, 2009 at 9:48:29 PM
Title Block - How do I insert a drawing title? |
Fri, Apr 20, 2012 at 12:18:43 PM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
