103 Users Online (102 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Pre Engineered Buildings Families
Wed, Sep 5, 2007 at 3:58:26 PM | Pre Engineered Buildings Families
DomColangelo
I'm a Revit newbie and I was wondering (hoping) someone knows of a downloadable and editable family of pre-engineered metal buildings.  Preferably one with a center column.  Thanks
Thu, Sep 6, 2007 at 6:55:58 AM | Pre Engineered Buildings Families
If you search this site under pre-engineered, you'll finda a couple of families.
This site also has pre-engineered components.  http://www.steelselect.com/resource_library/search.results.main.php?from=cad_library
Wed, Sep 17, 2014 at 10:53:17 AM | Pre Engineered Buildings Families
co1972nguyen
I need a Families only for Rafter of Pre Engineered Frame (see attached pictrure). I used to search Pre Engineered Buildings Families but did not see.
I'd like someone send this family to help me or show a away how to make it. Thanks in advance
Wed, Sep 17, 2014 at 10:59:41 AM | Pre Engineered Buildings Families
That is not a rafter - It is a pre-engineered rigid frame and they are in the downloads.
http://www.revitcity.com/downloads.php?action=search&keywords=pre-engineered&user_name=&sort=score
Thu, Sep 18, 2014 at 10:01:32 AM | Pre Engineered Buildings Families
co1972nguyen
Thanks. It's tapered beam and link
http://www.revitcity.com/downloads.php?action=search&keywords=tapered+beam&user_name=&sort=score
Thu, Sep 18, 2014 at 10:59:46 AM | Pre Engineered Buildings Families
Glad you found what you can use.
I think you need to talk to some Pre Engineered folks because what you posted is a rigid frame.  That is why you have the moment joint at the column that shows in the image you posted.  The rigid frame families are better suited for PE buildings rather than individual components like tapered beams.
Metal Panels for Pre-Engineered buildings
Thu, Dec 16, 2004 at 12:58:46 PM
Pre-engineered Metal Buildings
Thu, Feb 24, 2005 at 4:37:02 PM
Pre-Engineered Metal Building [ 1 2 ]
Tue, Sep 16, 2014 at 7:42:48 AM
17
Wed, Mar 25, 2015 at 8:01:35 AM
Metal Building
Thu, Oct 20, 2016 at 1:49:20 PM
Page generation time: 0.6827
