128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Copy during Align command?
Wed, Sep 5, 2007 at 1:38:06 PM | Copy during Align command?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is there a way to copy something with the align command?  Just like there is the 'copy' check box during the Mirror(MM) command?  Thanks,
Lorne
Denver, CO
Revit Architecture
Wed, Sep 5, 2007 at 2:56:44 PM | Copy during Align command?
justinblack
You can always, choose something... Then Ctrl+C (copy to clipboard) and then Edit > Paste Aligned > Same Place.
This will bring up a warning if you select an object vs a line.
Then just align the object again and you will have 2 like you requested.
Other than this I don't think there is a way to copy with the align command.  No there is no toggle on/off like the mirror command.
HTH
JB
Wed, Sep 5, 2007 at 4:57:50 PM | Copy during Align command?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Ok thanks JB.
Also everyone types HTH.  What does that mean?
Denver, CO
Revit Architecture
Wed, Sep 5, 2007 at 5:05:23 PM | Copy during Align command?
justinblack
HTH - Hope that Helps
Collaborate - Copy command changes type
Fri, Nov 6, 2015 at 1:35:15 PM
Revit wont align siding
Fri, Dec 2, 2011 at 8:46:34 AM
Auto Lock on align command
Wed, Mar 7, 2012 at 9:07:47 AM
Move/Copy/Align Masses
Thu, Jan 10, 2013 at 8:44:31 AM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:53 PM
Page generation time: 0.3947
