138 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Divide arc by length
Wed, Sep 5, 2007 at 1:24:26 PM | Divide arc by length
Oak3s
how do you go about dividing an arc into specific lengths? or how do you draw an arc with a 6 foot arc length? thanks for any help.
Fri, Sep 7, 2007 at 3:01:32 AM | Divide arc by length
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
Hi, when you drawing an arc you can prompt the radius, or the points related to the arc such as the start and the end oints or the centre. What you have to do is to define the radius graphically. After that tou can mesure it with the arc with an appropriate dimension tool: select the arc, the start and the end points, place the dimension. If you click on the arc you're allowed to edit the lenght of the arc but you can't change the radius (or the centre).
Hope this help you a little bit.
-Paolo
Fri, Sep 7, 2007 at 6:17:47 PM | Divide arc by length
Oak3s
That helped more than a bit. thank you.
Parametric Arc Sweeps - How to Bypass the Concentric Arc????
Mon, Jan 14, 2013 at 9:00:27 PM
divide a line
Wed, Sep 20, 2006 at 3:30:53 AM
Host wall thickness, in door schedule.
Mon, Nov 7, 2011 at 7:36:35 AM
how to divide a line or object in equal parts?
Tue, May 14, 2019 at 5:50:59 AM
12
Creating an Array along path
Thu, Sep 6, 2018 at 10:56:49 AM
Page generation time: 0.3593
