70 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> railing profile in project - not available in edit rails
Tue, Sep 4, 2007 at 5:58:36 PM | railing profile in project - not available in edit rails
Binnsdrafting
I have created a railing profile using "profile-Rail.rft" and when I load it into the project it is found in the browser but not in the "edit rails" dialouge box. I'm extremely frustrated as I've been trying to get this thing in there for over an hour to no avail. What have I done wrong? Revit Arch 2008
Tue, Sep 4, 2007 at 7:59:01 PM | railing profile in project - not available in edit rails
sdbrown
5 Stars: 3 Votes
Open the profile family, then under settings>family cat and parameters, check what the profile usage is set to. make sure its rail or generic.  If thats not the problem then you may have overlapping lines or lines not connected. try doing a tab select, delete, see if there is any line segments left. if there are then you have overlapping lines.
Fri, Sep 21, 2007 at 11:50:52 AM | railing profile in project - not available in edit rails
Binnsdrafting
sdbrown - thank you for your input. Your second suggeston was the trick - I had two lines crossing, once I redrew them and re-loaded it - wala - there were my profiles!
Thank you for your help!
Glass panel railing help
Fri, Jan 7, 2011 at 3:23:21 PM
Stringer as rail profile problem
Tue, Mar 25, 2014 at 8:27:14 AM
handrail profile not available
Fri, Dec 11, 2015 at 8:21:32 PM
Revit Handrails
Thu, Oct 20, 2016 at 1:45:57 PM
train rail help
Wed, May 13, 2015 at 4:20:30 PM
Page generation time: 2.2185
