40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensions and Leader Lines
Tue, Feb 1, 2005 at 3:38:33 PM | Dimensions and Leader Lines
jgjoh
Does anyone know a way to create dimensions that are not to scale? For instance, I am in a drafting view and I want my dimension to read "Varies - See Plan". I've been told this cannot be done but that is ridiculous. Also...is there a way to create a leader WITHOUT text attached to it?? We were told that you need to actually draw an arrowhead to do this. Once again...ridiculous! Help!
Tue, Feb 1, 2005 at 5:47:18 PM | RE: Dimensions and Leader Lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. You can add a suffix or a prefix to any dimension string, for instance for a 1200 dimension i might add a suffix "varies" thus the dimension would then read 1200 varies... Which i see as acceptable as at least one of the dimension will be this value... This is all to do with accuracy that revit provides and discourages fudging.... which is a problem in a lot of other programs. 2. This is true, in a way. You need to create a symbol (i've added instance parameters for length of arrow and size of arrow head). This is only a 2 minute job that you can then re-use in every project you ever create... HTH.
leader lines
Mon, Jan 19, 2009 at 2:39:06 PM
Adding Snaps to Leader Lines
Thu, May 29, 2014 at 7:34:34 AM
distance between text and leader lines able to be changed?
Fri, Sep 12, 2008 at 10:20:21 AM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:21:20 PM
Can leaders and dimensions be modified
Mon, Dec 22, 2008 at 11:02:52 AM
Page generation time: 0.5263
