128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair lines visibility (how can I make it disappear?)
Sat, Sep 1, 2007 at 1:35:30 PM | Stair lines visibility (how can I make it disappear?)
MazterMind3212333
3.5 Stars: 7 Votes
Good day
This maybe smple. I've created a u-shaped stair and above half of the runs is a floor. When I go to the upper level, I could still see the line of the runs beyond the floor. But if I viewed the site, the lines disappear! I've tried view ranges, graphics overrides and  still it doesn't work Thank you in advance.
Tue, Sep 4, 2007 at 12:23:09 AM | Stair lines visibility (how can I make it disappear?)
robinballew
robinballew Avatar
3 Stars: 4 Votes
Press VV or VG for visability graphic over ride of the view you want to adjust the display of the stair. Scroll down to stair and click on the + to open the stair options. Turn off Display above cut plane for stringers and stair... Should work...
BallewDesigns.com
Fri, Feb 20, 2015 at 10:01:28 AM | Stair lines visibility (how can I make it disappear?)
KYLIEBRAITHWAITE
This is just what I neede, thank you both!
Section lines disappear
Thu, Nov 26, 2009 at 5:14:07 PM
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:18 AM
13
Stair visibility issue
Sat, Jan 5, 2013 at 3:19:19 PM
Sketch Mode: reference linked dwg lines disappear
Wed, Oct 17, 2012 at 9:59:19 AM
Stair Visibility Issues
Fri, Jun 7, 2013 at 8:58:58 AM
14
Page generation time: 4.7820
