54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Toposurface - selecting imported instance
17 Posts No Rating |
I've done this before but now I can get it to work. No luck even with the tutorial files. I follow the tutorial to the letter but I can never select the imported instance. Revit Building 9.1 Thanks for any help, Doug
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
Make sure you import the file. Do not click on Active View only or Link when you import the DWG file..... It will not let you pick the file if you do have these checked..
----------------------------------- BallewDesigns.com |
toposurface problem!!! |
Fri, Nov 5, 2010 at 7:40:03 AM
Toposurface Using Imported Instance |
Thu, Oct 2, 2008 at 1:14:01 PM
Toposurface |
Thu, May 3, 2007 at 2:50:42 PM
Create a toposurface using imported files |
Sat, May 5, 2007 at 2:16:55 PM
Imported Toposurface |
Sat, May 5, 2007 at 3:39:33 PM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
