Forums >> Revit Building >> Technical Support >> Interior Elevation Boundary Lines
I need to make the boundary of the interior elevations of a room, a very thick line. I've tried to increase the wall cut line but that does not pick up the boundary where there are walls & doors. I would have to change the section cut line for walls, doors, windows, floor, & roof. Seems to be a lot. This is the same case when i've used tools-linework to select lines and change them its not as simple as picking 1 continuous box or the 4 boundary lines. What I would really love is to select the system family - interior elevations and make that box a fat #10 line. Any ideas for Revit Arch 2008? Thanks.
----------------------------------- Revit Architecture 2010 |
Select Crop region boundary>right click>Override Graphic in View>By Element>Change Lineweight to desired lineweight Don't forget to uncheck the "Hide Crop Boundaries" box in your "print setup" dialogue box.
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
Is this the same as boundry condidtions in graphics overrides? If not how can I apply this override to multiple views at once. I was thinking about doing it via view templates but I cant find the crop region under the overrides section.
Exactly...It can only be done on a per view, per instance basis...unfortunatley.
http://revitcity.com/forums.php?action=viewthread&thread_id=6504 see my reply to this thread. about the "object style" portion. What do we make of that, anything??
Interior Elevations - darker irregular boundary lines |
Wed, Oct 1, 2008 at 12:55:15 PM
Darker Interior Elevation Boundary Lines |
Thu, Aug 30, 2007 at 2:05:59 PM
Darker interior elevation boundary |
Mon, Nov 24, 2008 at 11:47:54 AM
elevation crop boundaries |
Fri, Jun 6, 2008 at 5:08:18 PM
Revit 2013- Adjusting the default setting for Interior Elevation crop boundary? |
Mon, Aug 26, 2013 at 4:23:48 PM
Members: | 2115606 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
