61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Dimensioning Parallel Curves
8 Posts No Rating |
I have two curved walls that are parallel to each other and need to dimension the distance between them (eg width of a corridor) Is there anyway to do this? at the moment I am having to draw detail lines to dimension to which isn't too accurate if anything moves and is time consuming. Thanks x
Detail lines is the way I would do it as well. Revit dimensions have to snap to smething not arbitrarty, it can snap to lines and defined static points such as an end point.
If you run a line from the center of the arc's to the outer arc, then you can trim that to the arcs. Add small pirpendicular lines at each end and this will give you your true dimension. You can delete the radius line or just place your dimension over it. Problem is it will not adjust if you change the arcs. REVIT needs radial concentric dimension capabilities.
Dimensioning 2 non-parallel reference lines |
Thu, Feb 14, 2008 at 9:40:47 AM
parallel curtain wall grid on curve? |
Wed, Jul 21, 2010 at 6:20:29 AM
sloped curved roof |
Sat, Mar 21, 2009 at 7:42:28 PM
Dimensioning a building on the site |
Mon, Mar 7, 2011 at 12:12:05 PM
blending curves |
Mon, Oct 13, 2008 at 12:22:38 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
