50 Users Online (49 Members):
Forums >> Revit Structure >> Technical Support >> Corrupt Imported DWG files
I am having issues with my dwg files that I've imported becoming corrupt and crashing revit. Anyone with an answer pleeeeeeez!
1 Posts No Rating |
For working out troubles with dwg data you can use recover dwg. It is able to view the results of restoring. The utility is compatible with all supported Windows OS. The tool is easy to use interface for any experienced users.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
use the recover and audit features in autocad.
Open a drawing using the recover command.
Once opened, audit with the option to delete corrupted elements.
6 years later & I still had this same problem! In my case, there were so many imported DWGs in the model that I didn't even know which one crashed Revit ![Sad](/images/smiles/sadley.gif)
For people desperately looking for a solution like I did, try to remove imported DWGs one by one and see which file is corrupt and delete it. You will probably need a Revit addin for this as there's currently no other way to see all imported DWGs in your file, unless it's small model. Addins like DWG Explorer can do this.
For me, I will make sure to only link dwgs from now on!
Imported dwg files |
Wed, May 10, 2017 at 10:25:29 PM
Annotations accidentally snapped into linked dwg (Imported categories) |
Tue, Jul 9, 2013 at 5:53:11 AM
Materials of Imported DWG files |
Sat, Oct 17, 2009 at 3:47:08 PM
Drawing Corrupt |
Mon, Jan 7, 2008 at 4:06:14 PM
EXPLODING IMPORTED FILES |
Tue, Oct 17, 2006 at 2:01:20 AM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
