70 Users Online (68 Members):
Forums >> Community >> Newbies >> View Range
1 Posts No Rating |
Hello All, I'm new to Revit Structure. I'm having some difficulty with the view range dialog box. The dialog box for view range at my foundation level has "grayed out" the inputs for the "Bottom Range". Because of this, the view depth cannot be set to a negative value and the plan view doesn't display anything below the cut plane. Does anyone know the cause of this? Thanks, dcshot
![Eddieboarder91 Avatar](user_avatar/37222.jpg)
![4 Stars: 8 Votes](/images/stars_4.gif) |
not sure of why it exactly does this but i believe that if you change the cut plane to neg. where you need to see the bottom should change along with it, transitive law tells you that you would be able to see your foundation not grayed out. hth
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
View Range |
Mon, May 17, 2010 at 4:48:55 PM
Members: | 2022302 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
