70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Massing Printing Problem-solve (sort of)-Revit Architecture (2008)
Fri, Aug 24, 2007 at 3:13:24 PM | Massing Printing Problem-solve (sort of)-Revit Architecture (2008)
justinm
This is more of an explanation of the differences between "massing" elements and "generic models" than a problem solve but it might be helpful to others...
I was struggling with getting massing elements to print as needed and I searched the "Technical Support" items for "massing and printing, etc." and I wasn't finding responses that fixed the issue.  In short, I had created a solid sweep using an in-place mass (Create>Mass>Solid Form...) that created a coping for a "monument" type of sign for a project.  I then applied a metal material to it (0% transparency).  The massing was showing correctly on all views and sheets but when printing, it would show up as if it were "wireframe" rather than "hidden lines."  "Show Mass" was on and under "Visibility/Graphics>Massing" everything was checked "on."
 The "fix" was to delete the "mass" and instead re-create the element as a "generic model" (Create>Generic Model>Solid Form...).  Now it prints fine.
I do not know enough about Revit to discuss the virtues of a simple "Mass" over a "Generic Model" but from a "newbie" perspective, I would say that a "Mass" should be used in an instance such as, you need a sloped wall, wherein you would create a mass with the slope needed and then create the wall "by face" and turn the "mass" off afterwards.  The mass is just a vehicle to get what you need, then is turned off.  If you need something like a stone parapet cap that will show solid in views and prints, then create a "Generic Model."
Fri, Aug 24, 2007 at 3:15:20 PM | Massing Printing Problem-solve (sort of)-Revit Architecture (2008)
justinm
Edit: Tip suggested by Rachel in Minneapolis.  Mad props Rachel!
working with massing - help! (Revit Architecture 2008)
Thu, Dec 20, 2007 at 9:32:50 AM
Massing printing problems
Tue, Feb 9, 2010 at 8:11:10 AM
massing problem in printing
Sun, Feb 14, 2010 at 7:36:21 AM
Revit 9.1 massing not printing correctly
Thu, Oct 4, 2007 at 11:12:47 AM
Printing Problem
Mon, Jul 23, 2007 at 12:53:22 AM
Page generation time: 2.4221
