43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> making viewport a polygon instead of rectangle?
Thu, Aug 23, 2007 at 10:33:19 AM | making viewport a polygon instead of rectangle?
DevinB
Is there any way to make a viewport a polygon instead of just a rectangle? I need to crop out a corner of the view to hide unrelated stuff.
 TIA-
 Devin
Thu, Aug 23, 2007 at 11:44:59 AM | making viewport a polygon instead of rectangle?
justinblack
Use a masking region to hide the objects, then turn off your crop region (looks better anyways).
JB
Thu, Aug 23, 2007 at 11:56:32 AM | making viewport a polygon instead of rectangle?
DevinB
I don't know why I didn't think of that, it worked fine. Guess I'm still used to AutoCAD in some ways...
Wed, May 6, 2009 at 9:34:09 AM | making viewport a polygon instead of rectangle?
koolair
4.5 Stars: 2 Votes
I've just duplicated my floor plan, adjusted the crop regions, and then added a masking region.
The floor plan covered by the masking region still shows up.  The above explanation makes sense to me, I guess I don't know how to adjust the visibility settings to the masked region.  Can someone help?
I've looked through the help file, but was not able to locate some concrete steps.
Thanks!
Views on sheets cropping eachother
Wed, Oct 21, 2015 at 1:17:36 PM
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
Stretch/move text location in Viewport Title
Wed, Sep 12, 2018 at 4:06:35 PM
DWG export glass to one polygon instead of two
Sun, Mar 26, 2017 at 12:58:52 PM
viewport annotation box
Mon, Jun 2, 2014 at 8:49:40 AM
Page generation time: 7.9213
