51 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Creating Dimensions with english and metric dimesnions on one string
3 Posts No Rating |
Does anyone know how to create a dimension string that includes english and metric dimensions on one string. ex: 100'-0" (35.5m)
![KimWong Avatar](user_avatar/9954.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
The way I would do this is to create 2 strings of dimension - 1 in imperial (100' - 0) and another in metric (35.5m) I will then align the 2 strings of dimension together but move the dimension text apart 100' (35.5 m) I doubt Revit will allow you to do 2 types of dimension on a SINGLE string. I asked this question as Autodesk Conference before. This is just more tedious. 2 times work here!
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
3 Posts No Rating |
thanks, sounds like the way to go.
Or you could just add text next to the original dimension. Or I guess there is always the option of using a suffix. Granted neither of these options are parametric (ie: accurate) JB
59 Posts No Rating |
Is there a good way to do this now, or will Revit still not allow you to have Metric and and SAE?
----------------------------------- Bradley |
The two strings is still the answer.
Conversion from English Units to Metric Units |
Tue, Feb 17, 2009 at 4:32:52 AM
Alternate Dimensions |
Wed, Dec 5, 2007 at 12:28:20 PM
dimensions with alternate units |
Tue, Feb 27, 2007 at 6:13:09 PM
Exploding Dimensions |
Fri, Jan 19, 2007 at 4:41:06 PM
dimension string problem |
Thu, Oct 18, 2007 at 1:21:31 AM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
