54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Revit 2008 & exporting alpha chennels
25 Posts No Rating |
In R9.1 it was easy to export a rendered image as a tif file.with sky set as a solid colour with alpha channel ticked. In photoshop it was easy to select the alpha channel and delete the sky. I can still go down the same road in 2008 exporting the image as a bmp file. In photoshop everything looks the same, layers and channels wise, but I get the message "no pixels selected", so presumably something has changed. I did find the feature most useful if anyone can help.
If anyone is interested, thelatest build of revit re introduces the tif export funtion for rendered images. problem solved.
Export to dwf alpha channel |
Mon, Feb 13, 2012 at 4:08:16 AM
Rendering without a sky (alpha transparent) (2010) |
Fri, Sep 18, 2009 at 9:45:49 AM
Alpha Channel? |
Tue, Aug 28, 2007 at 3:41:17 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008 |
Tue, Nov 20, 2007 at 12:37:43 PM
Can I use images with alpha channel? |
Sun, May 18, 2008 at 6:12:33 AM
Members: | 2030869 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
