66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning
Wed, Aug 22, 2007 at 11:05:20 PM | Dimensioning
lynx76
lynx76 Avatar
Hi, just wanna ask how do we put dimensions in a 3D view if I want to make an iso layout?  Well I've got a lot of questions, anyway, i'll ask them next time.   Anyway, I'm using Revit Architecture. Thanks.
Thu, Aug 23, 2007 at 3:13:16 PM | Dimensioning
broncos4life
4 Stars: 10 Votes
You can just dimension just like you do in floor plan.  The only trick is that you need to work alot with planes.  If you go into an iso all dimension will be put on level one.  So for every dimension you need to click on "Plane" and pick the plane that you want the dimension to go on.  Sounds more confusing than it is.
HTH
Grant Doherty
Wed, Aug 29, 2007 at 1:47:17 AM | Dimensioning
lynx76
lynx76 Avatar
thanks i got it.
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:57 AM
Dimensioning and then hiding objects?
Wed, Nov 7, 2012 at 2:34:01 PM
Isometric Views and Dimensioning
Mon, Feb 22, 2010 at 3:20:22 PM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 0.2266
