49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof eave/soffit gabled roof - RAC2008
Wed, Aug 22, 2007 at 4:41:35 PM | Roof eave/soffit gabled roof - RAC2008
t1slc
Been working on this for a while now and can't seem to get what I want. Attached is an image of the roof soffit/eave that I'm trying to get. I'm trying to create the soffit, but also fills in the little triangle left between the roof slope, the wall and a rectangular soffit. I have tried using a small wall with edited profile, but then all the linework shows and I tired to use the linework tool to adjust. However, when I did this all sorts of weirdness hapened. I tried to create a mass, which sort of worked but when I tried to convert the mass to walls the shape got all out of whack. I tried to create a similar inplace family, but ran into issues with linework again, in which some lines I would make invisible, but then another would take its place or the enitre line would go invisible but I only need the little triangle remainder to not show.
At any rate, what is the common (if there is one) method to creating this?
Fri, Aug 24, 2007 at 7:09:30 AM | Roof eave/soffit gabled roof - RAC2008
Dgodfrey
4 Stars: 4 Votes
We use the in place family method of extruding a triangle along the length of the soffit. I've tried using the built-in soffit feature but found it quicker the other way. Keep in mind that if you look closely at a boxed cornice whether it's wrapped in aluminum or cedar, there will be a seam between the slope of the fascia and the triangular closure. The attached picture is showing the 6" corner board and a 5/4 x 8" frieze board and the cornice and fascia are wrapped in aluminum coil stock.
Soffit Sweep / Roof Facia
Mon, Jul 14, 2008 at 3:06:40 PM
Roof Eaves
Wed, Aug 9, 2006 at 8:12:09 AM
Varying eave heights on roof [ 1 2 ]
Wed, Aug 11, 2010 at 8:21:38 PM
23
How do I make a gabled roof?
Sat, Jan 6, 2007 at 12:01:30 PM
butterfly roof, curved in plan and at eave
Sat, Feb 12, 2011 at 8:07:04 AM
Page generation time: 1.6053
