81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> PDF's with Revit
Tue, Aug 21, 2007 at 1:51:43 PM | PDF's with Revit
joedoglowe
4 Stars: 2 Votes
It would really be important to create a way to insert pdf files into Revit and plot to PDF from Revit.  If anyone knows how this can be done or will try to get a work around that would be great! Thoughts?
Joe Lowe
(619) 218-2841
Tue, Aug 21, 2007 at 1:59:00 PM | PDF's with Revit
matthewb
I'm not sure about importing PDFs, but a great free PDF plotter is at www.cutepdf.com
Tue, Aug 21, 2007 at 2:06:24 PM | PDF's with Revit
joedoglowe
4 Stars: 2 Votes
Thanks . . . I had just read about that in another thread and will try that. I also read that there may be a PDF to DWG converter which might work well for inserting PDF's.
 Thanks again,
Joe
Tue, Aug 21, 2007 at 2:19:27 PM | PDF's with Revit
matthewb
Your Welcome, Let me know how that PDF to DWG converter works out for you. That seems like it could be a very powerful tool.
-Matt
Tue, Aug 21, 2007 at 3:48:09 PM | PDF's with Revit
JHanby
3.5 Stars: 3 Votes
I came across this a few weeks ago.  Maybe its what you are looking for.
http://www.autodwg.com/pdf-to-dwg-converter/
Tue, Aug 21, 2007 at 6:57:09 PM | PDF's with Revit
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
this is the program is use to convert pdfs to dwgs
http://anydwg.com/pdf-to-dwg.html
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Tue, Aug 21, 2007 at 7:10:15 PM | PDF's with Revit
psymon
psymon Avatar
3.5 Stars: 6 Votes
If you have Adobe Illustrator there is an option to save to DWG.
The only problem of course is that the lines in the PDF have to be directly generated by a vector (cad) program. If the PDF is created by a scan or someother method, the information contained is just an image anyway an you might as well convert the PDF to a Jpeg.
Tue, Aug 21, 2007 at 7:34:27 PM | PDF's with Revit
joedoglowe
4 Stars: 2 Votes
Thanks for the suggestion, but when I tried to use Adobe Illustrator and save to DWG, it looked fine until I brought it into REVIT then it lost all line quality. Maybe it is a setting issue for when I link it ito Revit, or could be the way it is being viewed.  I take it you did not have this problem.  Any ideas why that happened?
Tue, Aug 21, 2007 at 7:43:02 PM | PDF's with Revit
psymon
psymon Avatar
3.5 Stars: 6 Votes
Probably for the reason that I lsited above. It is not vector information but raster information (an image).
Can you open it in Autocad? You will be able to see if the lines are true Autocad lines or an image.
Can't figure out PDF printing. Help!
Tue, Sep 12, 2006 at 4:39:08 PM
Printing PDF's
Tue, Oct 26, 2010 at 11:21:58 AM
pdf selections
Sun, Oct 22, 2006 at 3:24:53 AM
PDF's & Excel
Mon, Dec 12, 2016 at 6:17:39 PM
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
Wed, Aug 19, 2020 at 7:59:04 AM
Page generation time: 2.1250
