63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Problems while rendering with floor surfaces
Tue, Aug 21, 2007 at 11:08:52 AM | Problems while rendering with floor surfaces
knochcorp
I am new to Revit first off.  Whenever I go to render a room through a walk-through view the floor shows up splotchy almost.  I am just using a generic flooring and using paint for the seperate sections.  Parts of the flooring will show up fine and then parts will just show through to the generic flooring.  What and how much shows through depends on the angle.
 Is there any easy fix for this(I'm assuming its something easy I'm just overlooking)?
It is almost as if the floor is pixelated in regions.
thanks,
Dustin, Knoch Corp
Wed, Aug 22, 2007 at 8:59:01 AM | Problems while rendering with floor surfaces
matthewb
Does it help if you increase the thickness of the paint that you used for a floor finish? I usually don't use less than a 1/4" thickness for my floor finish when I do a rendering.
 -Matt
Turning floor surfaces off for individual floor elements?
Thu, Jun 29, 2006 at 1:31:20 AM
Rendering Curved Surfaces
Wed, Jul 19, 2006 at 8:27:38 AM
How to take quantities from painted surfaces?
Tue, Oct 10, 2017 at 1:00:43 AM
Problems with Best quality nighttime rendering.
Tue, Dec 4, 2012 at 8:32:13 PM
Angular surfaces
Fri, Oct 16, 2009 at 2:23:30 PM
Page generation time: 1.3634
