42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exporting from Revit
Tue, Aug 21, 2007 at 9:32:52 AM | Exporting from Revit
daveb867
IS there a way to export models from Revit into Max and those models (components) retain there shape.  I have a public toilet model, in Revit the toilets and urinals are nice and smooth, when i open it in Max there go all polygonated.  Is that a word????? : p, you know what i mean though, kinda of like pixelated but with polygons
Wed, Aug 22, 2007 at 9:43:11 AM | Exporting from Revit
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
So you obviously know to export a 3d model to a cad dwg. did you 1) set up your layers? so that not everything is same (layer0 i believe) 2) have you tryed exporting using acis solid? you will have to reapply materials and lighting, but i know its recommended to export as a polymesh. Also in max have you tried clicking on say a wall and going to its properties to see if there is an underlaying material currently applied?  i also have a pdf for max 9 that details how its done, ive attached it below. Hope some of this may have atleast pointed you in the right direction.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Trouble w/ exporting to AutoCad
Thu, Jan 20, 2011 at 11:18:07 AM
Exporting revit to use with Lumion
Tue, Jan 8, 2013 at 3:39:59 AM
Exporting from Revit and into 3D Studio Max
Wed, Oct 31, 2007 at 1:25:11 AM
Exporting REVIT 8 Model to Photoshop7
Wed, May 18, 2005 at 11:50:04 PM
Dimension problem when exporting Revit to DWG
Tue, Apr 12, 2011 at 11:15:43 AM
Page generation time: 4.0473
