43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Precast
Tue, Aug 21, 2007 at 8:02:37 AM | Precast
Andrea1983
My firm is looking at implimenting Revit, however most of our buildings are precast panels and I am struggling with a way to keep a wall as a whole but include the panel joints. Also the panel joints can't have any actual width to them (simply appear as a line) any advice?
Tue, Aug 21, 2007 at 10:01:06 AM | Precast
t1slc
Not exactly sure what you're thinking. But if all you need is a wall that shows panel joints, you can just use a surface hatch pattern. I quickly made a basic wall that you can take a look at... Using the align command you can lineup the joints however you want. The hatch pattern, if you use a model hatch, allows you to make whatever size panel you want. If you need a more custom, abstract, non-parallel joint pattern, I'm not sure how to do it, but you can always just use model lines on a basic concrete wall
If you want those panel joints to have depth and show shadow lines or something it's a little different, but I'm sure doable.
Tue, Aug 21, 2007 at 10:10:00 AM | Precast
Andrea1983
I think I understand what you did, however the panels need to be dimensioned in plan....I need vertical panel joints in both plan and elevation.  I think it is possible if I do a curtain wall system and just layout a vertical grid pattern, I was just wondering if something like this is possible in a basic wall.
Tue, Aug 21, 2007 at 10:26:06 AM | Precast
t1slc
hmmm, I suppose you could make a curtain wall system like you said. It's interesting that with the method I tried you can dimension the panels in elevation, but not plan. I suppose you could use reference planes or something to get them dimensioned in plan. I don't know what will be more work. I am, by no account, an expert with Revit. I'm interested in how this can be done, as I'll probably at some point need to be able to make rain screen walls with panels or planks and will want to show the gaps and dimension them as well.
Custom Precast Family
Fri, Mar 18, 2016 at 2:48:13 PM
split precast wall
Fri, Nov 24, 2017 at 1:17:56 AM
Precast on curved sloping wall
Sat, Nov 22, 2008 at 1:35:26 PM
Attaching railings to precast stairs [ 1 2 ]
Fri, Jan 16, 2015 at 6:37:54 PM
15
Precast Concrete Panels
Fri, Mar 31, 2017 at 12:28:40 PM
13
Page generation time: 0.1806
