36 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> Faint Text Issue
One of the building companies I draft for use Simplex & Roman text. They have asked me to make the text darker/thicker so it is not as faint when they print it out. I know revit does not have line weights for text but I was hoping someone may know which text would look simplier but print thicker as they have used this text style for yaers and don't want to changed. I was hoping to avoid using bold to thicken the text. Hope that made sense.
Macca Sunshine Coast QLD Australia |
We had the same problem using iso. You just have to hunt around for an acceptable font. We use ISOCPEUR which has a thickness associated with it. Unfortunately Revit has a few problems when trying to make an office style (as you would know), arrowheads, elevation marks etc.
Faint lines showing from ground floor on first floor |
Sat, Mar 10, 2012 at 4:40:33 PM
Text Line Weight |
Sat, May 5, 2007 at 11:34:38 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Problems when printing tp PDF using shadows |
Sat, Mar 21, 2020 at 7:41:02 AM
Text Scrambling Issue with Revit 2015 LT on Windows 8.1 |
Sat, Jun 13, 2015 at 11:17:05 AM
Members: | 2017490 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
