105 Users Online (104 Members):
Forums >> Revit Building >> Technical Support >> Importing A Revit Model
4 Posts No Rating |
I have been trying to import a Revit Building Model into my Revit Structure Model. I have done this in the past a few times with good results; however, the latest model I am trying to do this with comes in 286'-0" below the true elevation. I have tried different templates and get the same results; however, when I try someone else's model it works fine. I will usually do this to copy/monitor the Levels, Grids, Columns, Walls and Floors. This works really well for us, but at this point I am not sure what to do
This is a new client with whom I have not worked before with Revit, and it is a large project.
Any suggestions would be greatly appreciated.
![5 Stars: 3 Votes](/images/stars_5.gif) |
Just move the project up or down to match your levels, or move your levels up or down to match his, then acquire coordinates from his model.
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ] |
Sat, Apr 17, 2010 at 7:29:52 PM
19
Importing a 3D mesh model into Revit and creating the mesh to solids |
Thu, Dec 15, 2016 at 9:20:20 AM
Importing CAD to REVIT (vs. 2014) |
Mon, Nov 24, 2014 at 4:03:43 PM
Linked Revit model not importing in the correct orientation |
Fri, Nov 20, 2015 at 4:00:35 AM
Revit 2015 - Importing complex 3D DWG |
Thu, Apr 30, 2015 at 7:14:45 AM
Members: | 2017341 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
