51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Perforated metal screen?
Mon, Aug 20, 2007 at 3:00:01 PM | Perforated metal screen?
johnnyutah54
RAC 2008 - I'm trying to figure out the best way to create a perforated corrugated metal screen over a wall/curtainwall system.  It will be used as a shading device over the curtainwall system, and essentially as a rain screen over the wall portions.  Would it be best to do this as a component that is placed over the wall or as something that is part of the wall?  Any suggestions?  Thanks a lot.
Wed, Aug 22, 2007 at 12:42:26 PM | Perforated metal screen?
You could do this either way - depends if your screen always matches yor wall.  I've done similar using a wall against a wall.  In that manner, I could edit profile the screen seperate from the walls.  Far easier to edit that than a component.
PS - Here is a TIP.  You can set up your screen using one of the built-in AccuRender materials - screen under the steel material - change your color at will.  The problem is that the material will visully be non-transparent in non-rendered views.  What I have done that works, to overcome this, is to set your non-rendered indicatoion to be a cross-hatch pattern and set it to a transparency that will let you see through it.  You have to turn off the check box to update when accurender material is selected.
Thu, Apr 9, 2009 at 7:32:42 PM | Perforated metal screen?
designkern
I am reading what you guys did here, did you start it as a generic model created in place?  and you just let the accurender do the work, or did you punch voids through the solid.
Fri, Nov 12, 2010 at 9:21:26 AM | Perforated metal screen?
joncro55
Would a fine stainless steel wire mesh type of material act as the same thing you are looking for here?
Something like this:
 http://www.bwire.com/
Just a thought of an alternative that you may want to look at...
perforated metal or Expanded sheet metal [ 1 2 ]
Mon, Mar 5, 2018 at 5:55:55 PM
25
Perforated Metal Panels
Mon, Apr 26, 2010 at 11:46:50 AM
Perforated metal panel
Wed, Oct 30, 2013 at 7:36:34 AM
perforated brick screen wall
Thu, Oct 30, 2014 at 2:49:27 PM
Perforated Panel and Modeling
Tue, Jun 7, 2011 at 9:47:54 PM
Page generation time: 1.6793
