90 Users Online (88 Members):
Forums >> General Discussion >> Revit Project Management >> Problems during rendering with floors
3 Posts No Rating |
I am new to Revit first off. Whenever I go to render a room through a walk-through view the floor shows up splotchy almost. I am just using a generic flooring and using paint for the seperate sections. Parts of the flooring will show up fine and then parts will just show through to the generic flooring. What and how much shows through depends on the angle. Is there any easy fix for this? thanks, Dustin, Knoch Corp
3 Posts No Rating |
It's more so the floor is pixelated hopefully this image works on this forum format [IMG]http://i13.photobucket.com/albums/a278/datsunissan28/Walkthrough5.jpg[/IMG]
4 Posts No Rating |
The floor types are merging. try raising the floor .25" this usually helps.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
I think AR1237 is right. on another point, why do you render your walkthrough? obviously your render output is not for presentation, try shaded view with edges, much quicker and will look ok too
Problems with Best quality nighttime rendering. |
Tue, Dec 4, 2012 at 8:32:13 PM
Rendering Problems |
Wed, Jun 18, 2008 at 6:48:29 AM
12
Rendering problems |
Tue, Sep 12, 2017 at 9:55:21 AM
help with rendering! |
Wed, Aug 10, 2016 at 10:47:17 PM
Can a 63mb Revit File Size cause problems during rendering? |
Mon, Nov 2, 2015 at 6:29:45 AM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
