Forums >> Revit Building >> Tips & Tricks >> Cut geometry
Fri, Aug 17, 2007 at 11:29:33 PM | Cut geometry
cadjockey
Hi all,
I have created a kitchen cupboard family. This family can be placed anywhere and be adjusted in its dimensions. I have also brought in a sink family and positioned it accordingly in relation to the bench top.
Is there any reason why revit will not allow me to cut a hole in the bench top to suit the sink?
I thought the cut geometry tool works on anything?
cadjockey
Fri, Aug 24, 2007 at 9:15:57 AM | Cut geometry
GVS02
GVS02 Avatar
Can you edit the counter top and draw a hole in it? Usually I have found that is the easiest way. Just like you draw a floor or a mass, draw the outside face of the countertop as a closed loop, then add an inner loop for you sink. I hope this helps!
Sat, Aug 25, 2007 at 5:56:05 PM | Cut geometry
cadjockey
Thanks for the reply,
Yes I can.
I was trying to avoid this as it means I will need to create a whole bunch of cabinet families just to cater for the different sink holes and cabinet pofiles. It would have been nice if the sink you decide to use in your cabinet would autonatically cut the cabninet top as you place it.
I guess once I have set up the different familes I shouldn't have to repeat each time.
Better get started.
 cadjockey
Mon, Aug 27, 2007 at 10:17:27 AM | Cut geometry
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
If I'm understanding the process you are using correctly, you should be able to use your sink position parameters to make dimensions that correctly place your hole. You can add reference planes and parametric dimensions while in sketch mode to constrain your hole-cutting-lines to match-up with your sink. It's a trial and error thing, but you may be able to just pick-tool the sink ring and run with it.
Mon, Aug 27, 2007 at 1:50:42 PM | Cut geometry
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
(Deleted Duplicate, Sorry)
Edited on: Mon, Aug 27, 2007 at 1:51:14 PM
Cut Geometry in 3D
Sun, Aug 9, 2015 at 10:52:45 PM
Cut / Join - Geometry (api)
Tue, Jul 29, 2008 at 2:07:19 AM
Cut Geometry tool
Mon, Jan 13, 2014 at 7:30:04 AM
14
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Nested void geometry doesn't cut host solid
Mon, Dec 6, 2010 at 3:18:43 PM
Page generation time: 0.4690
