8 Posts No Rating |
Ok so I'm new to using revit so be kind here. Using RS2008. Have an Isolated footing under a post. Created a schedule with with the following fields: Type Mark, Foundation Thickness, Width, Length & I created an addition parameter field call Reinforcing. Everything schedules out properly except I get no reading for the "Foundation Thickness" column. all other column fill out perfictly. Under the Properties for that Iso FTG, Parameters: Dimensions, list Width, Length, & Thickness. The schedule is reading the Width & Length but not the Thickness. Did a Cont. wall Ftg. sched. had no problems. Can someone answer why the "Thickness" is not displaying under the THICKNESS column in my schedule? Thanks, Dave
David |
I'm not positve but I'm gonna give this a shot. I believe we had the same issue and found that if you change the schedule parameter to read the height instead of thickness, it should work. Like I said, I'm not sure. You can still have the word "thickness" as a column title in the schedule but just change the parameter. Let me know how that goes for you! JB
8 Posts No Rating |
Thanks JB, I looked and "Height" is not an availible field for Structural Foundations. They did have "Height Offset From Level" though...figured I try it but didn't work. I know I can create a Field for a new parameter and have it read that but I shouldn't have to....there's got to be a way for it to read the "Thickness" field under the Dimensions parameter in the properties of an Isolated footing. The family is "Footing-Rectangular" but I'm sure this was obviouse. Any other suggestions?
David |
