105 Users Online (104 Members):
Forums >> Revit Building >> Technical Support >> Sub Regions
6 Posts No Rating |
Hi all,
I was wondering if anyone else is experiencing problems with the new subregion tool in Revit 7.
1. I can not use the graded region tool in Phase 2 or i lose all the sub regions I've created in phase 1.
2. Even cutting and pasting the topo into phase 2 and trying to edit the subregion in phase 1 changes the phase 2 subregions.
Help
TM
I've never really tried using phasing with topography, but personally if its just so you can have two views that correctly show the before and after, then;
Create it as you want to view it in phase 1, then set to demolish all in phase 2, cut and copy all into phase 2 and edit to what you require. Technical it's not correct but should get around the problems you're having...
I'll keep you informed if I find a better way, after i've tried doing this.
HTH.
6 Posts No Rating |
Mr Spot,
I have tried doing it the way you suggested but still doesn't work. I think part of the problem might be it was a 5.1 Topo and has been upgraded to 6.0 then 6.1 now 7. I'm trying to avoid re-doing all the points. It's a large school campus.
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:27 AM
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:55 PM
masking regions |
Mon, May 11, 2009 at 4:31:49 PM
Where are Regions in the Purge List |
Tue, Feb 14, 2017 at 10:33:21 AM
Quick Help Needed - Masking Regions |
Fri, Jan 25, 2013 at 2:54:47 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
