47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Face based components in legends
![3 Stars: 5 Votes](/images/stars_3.gif) |
Any one else having trouble placing a face-based component in a legend? Using RAC 2008.
Yes, they are all coming in 90 degrees wrong. Any solution to this?
4 Posts No Rating |
Did you ever find the solution to the rotation problem? I'm in Revit Architecture 2010 and face based families insert rotated 90 degrees in a legend view.
![pchan Avatar](user_avatar/55190.jpg)
![5 Stars: 5 Votes](/images/stars_5.gif) |
The same issue occurred in 2011 I would say the workaround is to replicate the component in detail lines. you can trace over the component in legend view and then rotate it. It is not the smartest move but it works.
changing type of a family from wall based to face based |
Wed, Mar 3, 2010 at 8:24:37 PM
How would you modify a family from face-based or hosted to one that is not? |
Mon, Sep 26, 2011 at 8:39:50 AM
arraying a face based family around a curved face |
Thu, Oct 2, 2008 at 4:31:50 AM
Tutorial on creating REVIT Legends |
Fri, Oct 2, 2009 at 11:30:53 AM
Face Based Component - Default Load Settings |
Mon, Feb 15, 2016 at 10:23:49 AM
Members: | 2022349 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
