Forums >> General Discussion >> Revit Project Management >> Rendering?
5 Posts No Rating |
I am able to get through rendering a view through ray trace, but i do not know how to use radiosity Can any one here guide me through it?
So you've got your Render Scene (the same one you used for Raytrace) On your Design Bar, under the Rendering tab, click Settings to get the Render Scene Settings to pop up. Click Radiosity Settings, select a Quality value (the higher you select, the longer it will take to render. I find that Better usually does the trick, but play around with it if you have time to determine just how much time you want to invest for how much quality.) Under Solution Goal, select how many steps you want to use (this is how many times the light bounces around in the calculation. Again, higher humbers will give you a better quality, but will take much longer.) Select a value for Color Bleeding. This is how saturated (bright) your reflected light is (somewhere between 0 and 1. the closer to 1, the more like high noon the light will appear). Click OK and let your computer think. (maybe go get a cup of coffee if you don't have much RAM, like me). Take a Saturday sometime and just play around with different settings and qualities to figure out which ones give you the graphic quality you like. If in doubt, check the posts here, or, look into your help menu that came with Revit. Best of luck.
Ruth Rau Main Street Architecture, P.C. |
5 Posts No Rating |
Thank you Ruth Rau, Can radiosity be used for exterior renderings? Form whatever i came through with the help in revit, i came to know that radiosity can be used only for interiors? so how can i improve thr exterior renderings?
Radiosity can't be used for exteriors, its better u try for the sun & sky settings that can improve the quality of your exterior renderings or its better if u render the scene in 3ds max.
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
Also look at accurenderNxT http://nxt.accurender.com/forums/143.aspx
hi forget my last post revit 2009 should be released in a week or so and it has mental ray renderer built in. this should make all our renderings a lot better.
5 Posts No Rating |
Thank you (KingRevit) for letting me know abt the revit 2009 release. The below image that am uploading is rendered in revit and later given some touch up's in photoshop...
2 Posts No Rating |
Hey i know that this thread is about ray trace, but i just have a quick question. . . How or where can i find the "stone" patterns for my walls in the program? I have a structure built, but i dont like what the program offers( or maybe i dont know how to find it) So can anyone help?
Radiosity is used only for small architectural interiors, as the program will tell you when you try to use it. Before you use radiate... you will want to set a new scene up, to do this you go up to settings, then render scene, and save a new scene with the settings you want. You will want to try to group your lights into either rooms or floors and reconize the daylighting as well. If there isn't any, then you can turn the sun off as well as the groups of lights off that do not affect the render that you are producing. Radiate... will calculate the light in the room before you Raytrace, which gives you a more life like render. All of this will be obsolete in a way though in under 30 days. The new version of Revit that is coming out, which actually has mental ray built into the software. (A nod to King Revit.) Mental Ray is basically the same thing as 3d studio max. There are a couple of other programs out there that are good to use with Revit, other than 3d studio max, which are Maxwell Render and Piranesi. You should look up Piranesi anyway. It's basically 3d photoshop and more than likely what photoshop will eventually become. I hope that helps. Hold on for a month for the new Revit version and everything will change of course. I'm so excited myself, that I can hardly wait.
Realistic Rendering [ 1 2 ] |
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ] |
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue |
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009 |
Mon, May 11, 2009 at 4:32:50 PM
help with rendering! |
Wed, Aug 10, 2016 at 10:47:17 PM
Members: | 2114928 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
